oil tank foot valve
burnerman_2
burnerman_2 Member Posts: 297
have u tried this but if u are losing ur prime u may have a loose brass nut or a bad flare most times after u bleed the air unless there is a loose fitting u should not need a check valve royboy
  • Glen
    Glen Member Posts: 854
    for a used oil storage tank
    is there any commercially available and acceptable foot valves? 5/8 OD drop tube. trying to eliminate the drain back each time the burner (clean burn) shuts off.
  • Ed N.Y.C.
    Ed N.Y.C. Member Posts: 73
    Oil Line
    You have an air leak. Either at fittings,pump or tank. All a check valve will do is raise vac. and clog up after enough gunk gets stuck in it. Hope this helps ED
    mrcoder
