oil tank foot valve
burnerman_2
Member Posts: 297
have u tried this but if u are losing ur prime u may have a loose brass nut or a bad flare most times after u bleed the air unless there is a loose fitting u should not need a check valve royboy
for a used oil storage tank
is there any commercially available and acceptable foot valves? 5/8 OD drop tube. trying to eliminate the drain back each time the burner (clean burn) shuts off.0 -
