Pressuretroll Mercury Switch Pinned But Boiler Not Coming On
RonWHC
RonWHC Member Posts: 232
pigtail & any other syphon piping going to the pressuretrol.
  • Tom Hopkins
    Tom Hopkins Member Posts: 554
    If I pull the switch to off and let it snap back, boiler starts
    Lately, my steam boiler is not coming on a lot of the time when the T-Stat calls for heat.
    Upon inspection, I find the pressuretroll mercury switch tilted all the way back but it apparently is not making contact because if I pull the bulb foward and let it snap back the boiler fires right up. Sometimes I have to do this little flip the bulb thing twice.
    Do I need a new pressuretroll or is there something I could fix with the switch?
  • Mark Eatherton
    Mark Eatherton Member Posts: 5,875
    Do you have a multi meter???
    If you don't, it's kinda hard to trouble shoot. The problem may not be the switch. It could be the load, or maybe a wiring connection some place.
    ME
  • how old
    is the mercury switch? they do go bad. is the glass nice and clear or 'cloudy'?
