Two stage set up for vapor system (Steamhead)
gerry gill
gerry gill Member Posts: 3,083
as to wether or not low fire works well..for example a vapor system which heats very well at low fire..but was designed for it..if the boiler shuts off on pressure, there is even worse efficiency of on/off cycling..and often complaints of poor heat distribution..we use low fire very often..some customers say it saves money..some say the bills stayed the same..all say comfort has increased..
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=360&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
gwgillplumbingandheating.com
  • Ross_7
    Ross_7 Member Posts: 577
    Hi Frank,
    Can you give me any pointers for this set up? Maybe you could e-mail me the details.I have a pretty good idea, but any advice would be great. I was going to use a two-stage Uni-Line (Robertshaw) gas valve, tied into a vaporstat. Retro-fitting a Webster Type "R" system for our trades building. TIA, Frank!
    Ross
  • Steamhead (in transit)
    Steamhead (in transit) Member Posts: 6,688
    That's how it's done
    on the Weil-McLain LGB series atmospheric boilers- just a 2-stage gas valve (installed after the redundant CSD-1 valve which I would also recommend you use) and some additional controls. Obviously this is a CSD-1 situation, right? Here's a link to the CSD-1 manual for the LGB so you can see what's involved:
    http://www.weil-mclain.com/downloads/literature/lgb/lgbcsdgas.pdf
    What type of boiler is it, and what ignition system does it have? Is the Robertshaw valve made for use with this type of ignition system?
    Is there a minimum manifold-pressure spec you can use as a lower limit?
    The Vaporstat is wired to turn the high-fire stage on and off. Whenever there is a call for heat, the burners will run on low-fire if the Vaporstat is off on pressure, or on high-fire if not. Make sure there are no light-off issues on low-fire.
    Do a combustion test on both stages (but you know that). On low-fire you also want to make sure the flue temp is high enough to prevent condensing.
    "Steamhead"
  • don_185
    don_185 Member Posts: 312
    please share.
    Please share what advantage there is by going to a lower firnig rate on a gas appliance.
    From testing in the field I find that your thermal efficency is reduce big time going into low stage.
    Is it not a true statement to say lower thermal efficency = higher gas comsumption?
  • Ross_7
    CSD-1
    Hi Frank,
    Yes, we will be installing it per CSD-1, per MI Boiler code.
    Boiler is just a Crown Bermuda BSI-345. Intermittent pilot. Robertshaw gas valve model #700-064, which I belive is available on the BSI-376. I'll keep you posted. Thanks for the link, the help, Frank!
    Ross
    On Steam
    once the pickup factor is satisfied, the boiler becomes oversized and short-cycles. Dropping the firing rate by just the amount of the pickup factor shouldn't decrease steady-state thermal efficiency that much, and the lack of short-cycling should more than offset this.
    I haven't run into a steam heating system yet that wasn't originally designed for a lowered firing rate once it was heated up.
    "Steamhead"
  • don_192
    don_192 Member Posts: 45
    Thanks all
    Sorry Ross, for changing the subject.
  • Ross_7
    No problem, Don!
    That's why the wall is here.. to ask qustions!
    Thanks Gerry & Frank.
    Ross
  • Ross_7
