steam
George_45
Member Posts: 6
Yes. It could get to 215 when it gets to 1 1/2 psi. If you build up more pressure it will get even hotter
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=329&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
steam
is it ok to heat a indirect water heater[weil mcclain gold]..off of a steam boiler. the tank is being replaced every four years or so..[the tank is rated for 210 degrees]0 -
As long as
the tank is approved for use with a steam boiler. What type of tank are you using?
i dont know the model # but it s weil mcclain gold
weil mcclain gold ultra plus 800 -
That's basically
the Triangle Tube Smart unit. Nice indirect, my favorite for a hot-water system, but it doesn't like the water in a steam boiler. I'd use the SuperStor instead.
if the tanks rated for 210 degrees ...would that be the problem for the tank going every 3 to 4 years....for example if the boiler builds pressure could the water be more than 210?0 -
you think installing a bypass to mix return with supply water would help0 -
Hot temps
We installed a steamer a few days ago with a zone of heat on an internal coil . The temp at the coil maxxed out at 235 degrees . I was kinda shocked the temp could get that high on the coil side of a steamer .
Using an indirect with a steam boiler works very well . But like you said , make sure to pipe a bypass so the temp doesn't get too high going to the indirect .0 -
thanx guys for all the help0 -
Old Steam Radiator Valves
I'm looking for old combination open-closed/air vent steam radiator valves, can anyone help. We are close to Kansas City0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
