problem with Drayton room stat!!!!!!!!
ross_21
ross_21 Member Posts: 4
Hi, i'm attempting to change a honeywell three core plus earth wired stat for a Drayton batt operated stat (apparently only two cables required). The problem i have is this......the stat now turns the heating off when it should be on and vice versa any clues please?
  • Home Depot Employee
    Home Depot Employee Member Posts: 329
    You must be from across the big pond.
    Core being wires, without a full understanding, a few extra parts and a bit of tinkering, you will not be able to replace a 3 wire (core) stat with a 2 wire easily.
    Easiest way is to find a 3 wire (core) stat for your replacement.
  • Derheatmeister
    Derheatmeister Member Posts: 1,659
    what kind of zonevales do you have? WR, Power open,Power closed?
  • Derheatmeister
    If you have a power open/power closed zonevalve. then you need a three wire thermostat. Maybe you should ask carol fey on the bottom of the wall there is a "ask Carol fey" For controls. she really knows her controls.
