BASEBOARD ZONE
Mike,
I would use a Taco SR501 to control the pump with power from 4 N/O & neutral and a Honeywell L4006A wired with one leg in series from 5 & 6 N/0 to T T. Set the L4006A to 180 degrees max so you won't produce steam.
Bruce Marshall
  • Michael J. Brennan
    Michael J. Brennan Member Posts: 29
    BASEBOARD ZONE
    Which model/type aquastat & switching relay would you use to control a baseboard loop off a steam boiler? thanks for your help guys
    baseboard zone
    Thanks for the imput Bruce, sounds good
