HONEYWELL AIR CLEANER
Marvin_2
Member Posts: 1
Upgraded whole house air cleaner from standard pleated air filter (had to change every 3 weeks) to Honeywell F300 whole house electronic filter. Problem is that this unit has never filtered anything. It's been 4 months and the unit is still as clean as new. The power is ok and and the arc (snap) test is good. Honeywell has no answeres and even exchanged the unit--no help. Any suggestions??
EAC's
I've always been suspect of electronic air cleaners...until I look at the clean blower compartments after many years of service. Cleaner than media installations for sure. They must perform as advertised. The elements dont seem to collect much by cleaning time so I figure "where is the dirt going? "Zapped" into a fifth dimension perhaps?
I usually install four or five inch media on my higher end residential jobs. What thickness filter were you replacing every three weeks? If your curious temporarily install a 1" throwaway downstream of the EAC and see what it collects.0 -
Did you try putting one of the cells in a tub of hot water with dishwasher detergent in it. Even though the cell looks clean, the water will turn dark--provided the cell hasn't been washed in a couple months.0
- 120 Geothermal
