hot water expansion tank
Al Letellier_9
Al Letellier_9 Member Posts: 929
Yes. On the cold line between the tank and the check valve. Make sure and use the right tank....for potable, open systems, not for hydronic systems
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=522&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
  • john_156
    john_156 Member Posts: 2
    i am installing a super stor indirect hot water heater, i have a recirculating loop ....there is a check valve on the cold supply ..question...does the expansion tank have to be between the check valve and tank(in the cold line coming in), or can it be on the hot side ( in the hot line leaving the heater)thanks in advance for any advice on this...john
  • Aidan (UK)
    Aidan (UK) Member Posts: 290
    Hot water expansion tanks
    All unvented water heaters sold in the UK are required to have an expansion vessel by the Water Regulations. The expansion vessels are invariably on the cold feed pipe, so that the diaphragm is not exposed to hot water.
