Radiator not getting warm at all
kevin coppinger_4
Member Posts: 2,124
hot water system ?
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=323&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Radiator not heating up
After replacing a radiator (last one on the run) it no longer heats up. It did at first but then it stopped. Husband installed it, it has micro bore cooper pipe but has an exension of a larger bore added at the bottom end. Can you please advise as to what the problem may be please.
After replacing a radiator (last one on the run) it no longer heats up. It did for quite a while (months) but then it stopped. Husband installed it, it has micro bore copper pipe but has an exension of a larger bore added at the bottom end.Ther is no air in the pipes and the inlet pipes are not getting warm either. Can you please advise as to what the problem may be please.0 -
Make sure the rad is bled and the rad valves are fully open.
Turn off all the other rads and keep the problem one open. Then turn on the heating if it is an air lock in the pipework this should shift it.
Andy0
- 167 Indoor-Air Quality
