Radiator not getting warm at all
hot water system ?
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=323&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
  • Den
    Den Member Posts: 2
    Radiator not heating up
    After replacing a radiator (last one on the run) it no longer heats up. It did at first but then it stopped. Husband installed it, it has micro bore cooper pipe but has an exension of a larger bore added at the bottom end. Can you please advise as to what the problem may be please.
  • Den
    Den Member Posts: 2
    After replacing a radiator (last one on the run) it no longer heats up. It did for quite a while (months) but then it stopped. Husband installed it, it has micro bore copper pipe but has an exension of a larger bore added at the bottom end.Ther is no air in the pipes and the inlet pipes are not getting warm either. Can you please advise as to what the problem may be please.
  • Andy Byrnes
    Andy Byrnes Member Posts: 42
    Make sure the rad is bled and the rad valves are fully open.
    Turn off all the other rads and keep the problem one open. Then turn on the heating if it is an air lock in the pipework this should shift it.
    Andy
