hot air furnace humidifier
bill_71
Member Posts: 46
aprilaire.........easy to work on, everyone carries their pads around these parts
furnace humidifier
Have to ask........ which manufacturer and type of unit do you guys recommend for a forced hot air furnace? I have a Williamson model T277710 hi-boy oil furnace. Many thanks for your suggestions.0 -
keep in mind
Keep in mind that with a poor envelope, you will find times that your humidifider will not even keep up when it relly cold and dry outside.
So if you have a poor envelope pick one that would give you the highest capacity.Also it would be best to pick one that will work on it own and not only when the furnace is calling for heat.
I'm a steam fan when it come to humidifider.0
