hot air furnace humidifier
bill_71
bill_71 Member Posts: 46
aprilaire.........easy to work on, everyone carries their pads around these parts
  • mike8
    mike8 Member Posts: 12
    furnace humidifier
    Have to ask........ which manufacturer and type of unit do you guys recommend for a forced hot air furnace? I have a Williamson model T277710 hi-boy oil furnace. Many thanks for your suggestions.
  • don_185
    don_185 Member Posts: 312
    keep in mind
    Keep in mind that with a poor envelope, you will find times that your humidifider will not even keep up when it relly cold and dry outside.
    So if you have a poor envelope pick one that would give you the highest capacity.Also it would be best to pick one that will work on it own and not only when the furnace is calling for heat.
    I'm a steam fan when it come to humidifider.
