Furnace Messes up T.V. Picture
realolman
Member Posts: 513
are your priorities, man?...... Get rid of the furnace! ;-)
T.V. and Phone interference
Any one know why when a furnace comes on it makes the snow fall on the t.v. set. Cable t.v. also has static on the telephone. Feed Back appreciated. Thanks0 -
Interferance
Check your grounding on the furnaces electric feed, that is if the furnace is newer with electronic ignition0 -
TV interference
On oil burners it might be a good idea to look over the porcelain insulators on the electrodes.
Hairline crack in the porcelain can show up on a TV screen.
Good luck,
NelsThere was an error rendering this rich post.
TV
Also check the ignition transformer... have had to replace them to stop the interference. (insulation breaking down seems to be the culprit)0 -
Shoot the TV...
get a good book, and curl up next to the heat register :-)
Problem solved... NEXT!!!
Happy Gnu Ears to ya'll.
ME0 -
Grounding
Check that the blower motor case is grounded correctly. I have seen situations where the ground path found its way through the bearing and created all sorts of RF noise.
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"There was an error rendering this rich post.
- 167 Indoor-Air Quality
