Outdoor boiler
hot_rod
hot_rod Member Posts: 26,626
well in some areas. certainly more of a rural area device. Even then with the right, or wrong, weather conditions they can bother a lot of neighbors.
A hot clean fire helps, as does the proper size unit or buffer tank.
hot rod
