Bradford White Water Heater w/Power Vent
mmoreno
Member Posts: 1
I have a 10 yr old 70 gal water heater and have recently replaced the pressure switch since I was having issues with the call for heat. It started acting up again and the burner would not kick-in after hot water usage.
Is there another part which may also have to be replaced as the power vent motor runs a long time (up to an hour) after the request for hot water?
Marc
Marc
Sound like you may need an igniter
look inside and see if you can see it glowing on a call for hot water. If not then check to see if you have 120 VAC to the igniter if yes and the igniter does not glow you need a new one.0 -
I'm not an expert on BW but a lot of these power venters have a diaphram prover switch on the blower to ensure it's running b/f the gas valve can open. Your switch may be shot. Should be a tube coming off the vent somewhere going to a little round plastic thingy with wires going down to the gas valve? If your blower is running you can sometimes jumper the prover wires & see if the thing fires. Just make sure you don't just leave the jumper in & not replace the switch if it's bad.0 -
Model no.? You may have a defective spill/purge switch in the venter housing.0
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 107 Geothermal
- 983 Plumbing
- 389 Solar
