New Vitoden throwing Fe code?
hot_rod
hot_rod Member Posts: 26,633
an outdoor sensor code which I disconnected and cleared. then idt went to the Fe code. it's a 6-24 combi. Pump runs, water and gas pressure OK. Heat exchanger purged.
I went through all the code address with the factory support, all they could come up with was a bad board. Been waiting a week for a new C3PO board or whatever it's called :)
Move in day tomorrow, sure would like to get the gal running. Thanks for any tips or tricks.
hot rod
