New Vitoden throwing Fe code?
hot_rod
Member Posts: 26,627
an outdoor sensor code which I disconnected and cleared. then idt went to the Fe code. it's a 6-24 combi. Pump runs, water and gas pressure OK. Heat exchanger purged.
I went through all the code address with the factory support, all they could come up with was a bad board. Been waiting a week for a new C3PO board or whatever it's called :)
Move in day tomorrow, sure would like to get the gal running. Thanks for any tips or tricks.
hot rod
hot rod
Is it...
the LGM burner board? I've never done the combi 6/24C but have had to deal with a few bad LGM boards. I now have the rep stock at least 2.
I always have Viessmann tech services out of RI send overnight any defective parts, if the rep (or my truck) doesn't have them. An RGA form is filled out for parts credit.
Looking forward to seeing you and Ellen at Wetstock!!
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
