insulation
Don Regan
Member Posts: 43
We use Crete-Heat for this very application all the time.
insulation
I have a pole barn with a dirt floor, I want to put 2" board insulation, wire mesh and tie the pex to that. My concern is the insulation supporting vehicles?0 -
IF you ...
prepare the underneath properly you shold be fine. There are diferent grades of styrofoam...make sure to check ut the psi rating? What are these vehicles? How think a slab?0
- 87.8K THE MAIN WALL
- 131 Chimneys & Flues
- 79 Pipe Deterioration
- 396 Solar
