insulation
We use Crete-Heat for this very application all the time.
  • insulation
    I have a pole barn with a dirt floor, I want to put 2" board insulation, wire mesh and tie the pex to that. My concern is the insulation supporting vehicles?
  • kpc_21
    kpc_21 Posts: 4
    IF you ...
    prepare the underneath properly you shold be fine. There are diferent grades of styrofoam...make sure to check ut the psi rating? What are these vehicles? How think a slab?
