Sandblasting radiators?
Jason_44
Jason_44 Member Posts: 60
Wouldn't that cause rust to build up on the surface almost immediately?
Jason
  • Jason_44
    Anybody here have any luck sandblasting paint off radiators themselves?
    I know a guy who does it professionally, but it's about $200 per radiator. Was thinking I'd maybe get a cheap camping tent and try blasting my own (inside the tent to contain everything) using a shop compressor. Anybody have any experience with this?
    Jason
  • wsdave
    wsdave Member Posts: 97
    Radiators
    I used paint remover and my Craftsman power washer.
    Worked out great!
    HTH
    Dave
  • Big Ed_4
    Big Ed_4 Member Posts: 3,369
    Sand Blasting
    Sand Blasting uses massive amount of cubic feet of air. I don't know what size compressor you have. But you could be there all day waiting for it to build up.
    Where I go to have stuff blasted is tomb stone makers. They use huge compressors and are all set up for heavy items. And if they are slow they can blast it right away.
  • wsdave
    Rust
    Nevaer had that problem Jason.
    When I removed all the paint I immediately dried radiators off using compressed air (and lots of sun).
    Sprayed with primer after that.
    Dave
