Help a family in time of need
There are two new donations to add to the boiler package:
12-(twelve) Taco 007 Circulators donated direct from the Taco Corporation.
1-Set of custom headers donated by Earth Lee Ltd.
We are coming down the Home Stretch with the Carl Tomberlain Benefit Auction. Keep in mind that all of the equipment listed below has been donated. The full amount of the winning bid will go to "The Carl Tomberlain Benefit Account" to help the wife and two young daughters that Carl left behind. Thanks to all of you that have placed bids to date. Please e-mail your bids to me at kebers@verizon.net
You are bidding for the following boiler package:
1-Crown TWZ-100 3 Section Cast Iron Wet Base Oil Fired Boiler, 1.00GPH, 120,000 G.O., either with or without Tankless Heater.
1-Carlin Burner for above boiler.
1-Honeywell Programmable Thermostat.
1-Honeywell Boiler Trim Kit consisting of Expansion Tank, Super Vent and Fill Valve/Back Flow Preventer.
1-Hydrolevel Low Water Cutoff.
1-Taco 007F (in addition to the one that comes with the boiler).
1-Taco SR501-EXP Switching Relay.
1-Roth 10001 (275) Double Wall Oil Tank complete with Installation Kit.
1-Williamson/Thermoflo DHW-36 Stainless Steel Indirect Fired Hot Water Heater.
1-Beckett Heat Manager.
1-Set of custom headers built to your specifications by Earth Lee Ltd.
1-Free Delivery by Avco Supply in the Philadelphia Tri-State Area. The delivery charge out of the area will be the responsibility of the winning bidder. A pick up can also be arranged at Crown's Factory.
I will keep you informed by periodic e-mail of the dollar amount of the high bid. The name of the high bidder will not be divulged until the end of the auction on 12/7.
Thanks for all your bids to date! So far, the High Bid is 2,300 Dollars and the auction will end on Friday 12/7 at 5pm. The Auction has only 2 days left.
Sincerely,
Ken Ebers
Crown Boiler Company
  • Boiler Auction to help the Tomberlain Family
    I am posting this for a group of people who care and want to help a mother and two young children who have had their husband/father taken away from them. Some of you may or may not know about Carl Tomberlain and his surviving family. You may have seen the story on national news on November 7th. http://cbs3.com/local/Carl.Tomberlain.North.2.566353.html
    Carl worked for PETRO as a Service Tech and was shot and killed while responding to a no-heat service call recently in Philadelphia. We would like to raise some money to benefit Carl's wife and two daughters in a time of great need.
    This auction idea started when Larry Steingard, President and Yale Steingard, Vice President of Crown Boiler donated a boiler to help a local family connected to our industry that had just faced a terrible tragedy. Larry and Yale are joined by a few local vendors who donated boiler accessories to make up a great boiler package.
    The equipment listed below has all been donated and will be auctioned off as a complete package. ALL of the winning bid money will be donated to "The Carl Tomberlain Benefit Account". The starting bid was 750 dollars and the auction will end on 12/7.
    Ken Ebers of Crown Boiler is organizing the auction and consequently is taking all the bids. You can e-mail your bid to Ken at kebers@verizon.net or you can call him with your bid at 215-264-7307.
    Again, to bid contact Ken Ebers of Crown Boiler. You can e-mail your bid to Ken at kebers@verizon.net or you can call him with your bid at 215-264-7307.
    If you place a bid Ken will keep you informed by periodic e-mail of the dollar amount of the high bid. The name of the high bidder will not be divulged until the end of the auction on 12/7.
    Thanks for all your bids to date! So far, the High Bid is 1,500 Dollars and the auction will end in just over a week.
  • st heat
    st heat Member Posts: 28
    donation
    steven that is very nice.let me know if i can donate a little something in addition to the auction. st.
  • I'll check into that.
    Steven,
    Thanks for asking. I'll look into this and let you know.
    Steve
  • DanHolohan
    DanHolohan Member, Moderator, Administrator Posts: 16,687
    Good stuff.
    Thanks, Wheels.
    Retired and loving it.
  • burnerman_2
    burnerman_2 Member Posts: 297
    lets do it
    if u can get an address where a trust fund is in place lets all give i hr (money )to help this fanily out i am sure the co or a family member has set one up list it on here i will send a donation and many others will i cannot buy a boiler but if we all send 20 bucks they will have a great christmas royboy
  • Ken Ebers
    Ken Ebers Member Posts: 8
    A fund has been established with the help of the local Petro Branch that Carl worked for to assist his Family:
    Checks should be made out to: "The Carl Tomberlain Benefit Account"
    Send to:
    Bob Gussoni
    c/o Petro
    650 Knowles Ave.
    Southampton, PA 18966
    An additional point of interest: Roth Industries has very kindly donated a Roth 10001 (275) Double Wall Oil Tank complete with Installation Kit as part of the boiler package above that is up for bid to help Carl's Family.
    Ken
  • Add One Roth Tank COMPLETE!
    If you missed the bottom of Kens post Roth has added a tank to the package!
    Very cool. Thanks ROTH! (or whoever donated the tank)
  • No Dan THANK YOU!
    for having this medium that we can use for be greater benifit of mankind :-)
    wheels
  • Ken Ebers
    Update: Williamson/Thermoflo Indirect Added to Tomberlain Benefi
    The Williamson/Thermoflo Company has just donated a DHW-36 Stainless Steel Indirect Fired Water Heater to the Carl Tomberlain Benefit Auction that you are bidding on below:
    1-Roth 10001 (275) Double Wall Oil Tank Complete with Installation Kit.
    Thanks for all your bids to date! So far, the High Bid is 1,800 Dollars and the auction will end on Friday 12/7 at 5pm. The Auction has only 5 days left.
    Sincerely,
    Ken Ebers
  • Only 5 days left!!!
    Ken,
    This has become a GREAT package.
    Steve
  • Beckett Just Added!!!
    Add to this great auction a Beckett Heat Manager!
    WOW, this has become a GREATER the GREAT package!
  • Lee_2
    Lee_2 Member Posts: 48
    donation
    I will donate the manifolds if you let me know the size and outlets required.
  • Thats excellent
    I'm not sure even the buyer will know until they actually use the boiler BUT maybe based on the BTU you can put up a generic size??
    Thanks,
    Steve
  • Ken Ebers
    WILO donates $2,000 to the \"Carl Tomberlain Benefit Account\"!
    ----- Original Message -----
    To: kebers@verizon.net
    Cc: Cheryle Lowe
    Sent: Sunday, December 02, 2007 5:27 PM
    Subject: Auction
    Hi Ken, WILO USA will donate $2000 to this. We do not wish to bid on the Boiler System we only wish to help the cause. Please advise where to send the check.
    Thank you for your efforts!! This is such a sad story.
    Best wishes, Bill
    William (Bill) Lowe
    President
    WILO Canada Inc.
    bill.lowe@WILO-NA.com
    WWW.WILO-NA.com
  • WOW!
    Ken,
    I can not believe there is now soo much in this package!
    What a great way for us to help a family in need!
    Thank you for putting all this together and staying on top of it!
    Steve
  • Ken Ebers
    Benefit Auction Ends Tomorrow (Friday 12/7) at 5pm---$2,400
    We are down to the last day of the Carl Tomberlain Benefit Auction. Keep in mind that all of the equipment listed below has been donated. The full amount of the winning bid will go to "The Carl Tomberlain Benefit Account" to help the wife and two young daughters that Carl left behind. Thanks to all of you that have placed bids to date. Please e-mail your bids to me at kebers@verizon.net
    Thanks for all your bids to date! So far, the High Bid is 2,400 Dollars and the auction will end tomorrow (Friday 12/7) at 5pm.
    In the event of tie high bids at the end of the auction, those bidders will be asked to submit another bid until a winner is determined.
    Sincerely,
    Ken Ebers
  • Only 7 hours left to bid!!!
    Hopefully someone will raise the bid!!!!
    5K (TRADE COST) worth of equipment offered here. C,mon guys!
  • Ken Ebers
    Winner of the Tomberlain Benefit Auction is.....................
    The Carl Tomberlain Benefit Auction is now officially over!
    I want to thank Larry and Yale Steingard of the Crown Boiler Company for launching the idea of an auction when they offered to donate a boiler. Thanks to all of the Manufacturers and Rep Organizations that made equipment donations so that we could have a complete boiler package to auction off.
    The Auction would not have been the success it was without the support of Judy Garber at NAOHSM, Alan Mercurio with “Oil Tech Talk”, Dan Holohan with Heating Help.Com and Wally Nowicke & Steve Wieland at Avco Supply. Thanks, also, to the many individuals, organizations and companies that made cash donations to the Carl Tomberlain Benefit Account.
    The largest debt of gratitude, however, goes out to all of the bidders that made the auction a huge success! The bids were truly overwhelming and came from all over the east coast.
    Listed below are the top 6 bids:
    $3,600—Duckett & Laird
    $3,500—Oil Heat Cares
    $3,500—Harris Comfort
    $3,200—Meenan Install Tullytown
    $3,000—Walter A. Dwyer
    $3,000—Foley Mechanical
    Please join me in congratulating Duckett & Laird as the Winner of the Carl Tomberlain Benefit Auction!
    Thanks again for all the support from the bidders and all the wonderful people that helped with this project.
    Sincerely,
    Ken Ebers
