If You are so INCLINED...can over-pitching cause Water Hammer?
Steamhead (in transit)
Member Posts: 6,688
if that's the main in the crawl space, check to see if there is too much water in the boiler. This will flood that main, causing banging.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=367&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Is too much too much?
I have a one pipe steam system (gorton) and am wondering if a radiator has too much incline, can this be the cause of a water hammer? Pipes are well insulated, and this radiator is at the long end of the main...I recently removed all the radiators and stripped/repainted them (whew!) and reinstalled...THANK YOU for your suggestions!0 -
If there's sludge inside the radiator,
which there often is, over-pitching the radiator can cause it to shift and form a pile, behind which water will collect and hammer when steam arrives. You need just 1" in 10' when pitching a radiator. That's not much.Retired and loving it.0
- 167 Indoor-Air Quality
