i series mixing valve
Greg,
Like anything else, installed correctly in the right application these are grat valves at a great value.
So far I have not had one fail. Of course they have only been out for 5 years, but no failures.
Steve
aka wheels
  • greg_47
    greg_47 Member Posts: 9
    does any one have any experienc with Taco's i-series mixing valves.... what might be the life span of the product and does it work well.. what about sizing for flow rates?
  • ScottMP
    ScottMP Member Posts: 5,882
    I disagree with Steve
    I don't think they are grat.
    I DO THINK they are great and you alot of them. I don't belive we have had any problems other than "installer error". Make sure you have the ports aligned with the valve head and we don't like to use the boiler sensor. We just feel it works better with out it.
    I do think Steve is Grat !!
    Scott
  • see we both agree....
    I am great :-)
    but for the price the I series has it place. Thats not all places, but they have their place.
    wheels
  • i've heard they are noisy. is that true?
  • DanHolohan
    DanHolohan Member, Moderator, Administrator Posts: 16,713
    Wheels
    is noisy.
    And grat! :-)
    Retired and loving it.
  • never had a complaint
    about the noise from a I series. I have had complaints about how noisy i am. :-)
    when it comes to the i-series, as they say, i can;t hear them at my house
    and thanks for the compliments. I always wanted to be Grat!
    wheels
  • J.C.A._3
    J.C.A._3 Member Posts: 2,980
    Rob,
    They DO make a bit of noise when the call for heat comes after a setback...as they "hunt" to adjust the wanted temp. .Once the return water comes up to that magic Delta T...they calm right down and are quite amazing.
    Biggest thing is just what Scott said. Proper orientation on the body,( wire connections over the inlet /high temp. water), and also make sure the dip switches make the valve do what you need it to.(See: read the instructions) Chris
  • John_Barba
    John_Barba Member Posts: 166
    iValve...
    Greg --
    Email me your contact information and I can help you out with any specific questions you may have regarding sizing, programming, etc. As the others have said, the iValve is a pretty versatile little device. And Wheels is beyond Grat. He's absolutely Cugat!
    JMB
  • Joe Mattiello
    Joe Mattiello Member Posts: 751
    Good Morning
    Your inquiry about the I-series can be best answered with knowledge about the product. Taco has some great informational resources available at Taco-havc.com. Look up the radiant made easy application guide for a product overview, and why one product might be better then another in different applications. For your reference I attached the guides for the reset, and set point I-valves. These valves are a great tool for tempering water based on either outside temperature, or a specific set point temperature. As for the noise issue; the valves are a ball valve type valve which continuously modulates so the system water requirements are satisfied. You might hear the small electric motor turning on and off when the valve orifice needs adjusting, but nothing that would be considered unreasonable.
    Joe Mattiello
    Taco Comfort Solutions
  • Rocky_3
    Rocky_3 Member Posts: 236
    Have use numerous 3-way I-valves
    and now am using using several of the 4-way valves. Have had the I-valves in for over 4 years and not one lick of problems. I feel they solve a lot of otherwise expensive problems.
    Rocky
  • Jeff Elston_2
    Jeff Elston_2 Member Posts: 20
    Your so grat!!!!
    and loud my ear still hurts!
    I sent Craig your way today... your welcome oh Grat one!!!
  • ScottMP
    All kidding aside
    I think its a really good product and have No Noise issues.
    We use them ALOT and have 0 call backs.
    Scott
