Thermostats
fatty
Member Posts: 46
What kind of thermostat would be good in an building with 4 small zones (about 500 ft2 each) that are entirely separated and have tenants that might try to noodle with the settings? The zones will be on a 4-zone taco control.
Do they all have to go into a lockbox?
Thanks a hundred
Fats
Thanks a hundred
Fats
A lock box on an inexpensive thermostat is probably going to be the least expensive. You could use a locking thermostat, but that will be a higher end stat, such as the Honeywell TH8320.0 -
T-stats
Try a t-stat with a remote bulb. There are several available without too much money.0
- 87.2K THE MAIN WALL
- 118 Chimneys & Flues
- 164 Indoor-Air Quality
- 73 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
