Thermostats
What kind of thermostat would be good in an building with 4 small zones (about 500 ft2 each) that are entirely separated and have tenants that might try to noodle with the settings? The zones will be on a 4-zone taco control.
Do they all have to go into a lockbox?
Thanks a hundred
Fats
  • carol_3
    carol_3 Posts: 397
    A lock box on an inexpensive thermostat is probably going to be the least expensive. You could use a locking thermostat, but that will be a higher end stat, such as the Honeywell TH8320.
  • Ken D.
    Ken D. Posts: 836
    T-stats
    Try a t-stat with a remote bulb. There are several available without too much money.
