BSPT British Standard Pipe Threads on Myson panel radiators
Brits X NPT do you need, I believe I may have access to a conversion fitting.
Rich K.
  • Bob Haley
    Bob Haley Member Posts: 11
    BSP British Standard Pipe Threads Myson panel radiators
    Walked in on a job where as many as 10 of 22 threaded joints on 11 Myson panel radiators were leaking slowly. We removed all the radiator unions to find out they are straight thread BSP (no taper). Myson's instructions using supplied Loctite 565 apparently did not work for original contractor. We used Teflon tape and Blue Block (which has a 100% success rate with our NPT connections)with 6 of 22 leaks! We then tried 4 of the leaking joints with Loctite 565 on both male and female threads and waited 24 hours to cure before pressurizing the zone. That worked, but I'm open to suggestions. Myson has many good products but this one needs work.
  • ALH_4
    ALH_4 Member Posts: 1,790
    Loctite 545
    Loctite 545 Thread Sealer works. It's purple, the consistency of thread locker. I have used it many times.
  • Rob Blair
    Rob Blair Member Posts: 227
    Loctite 55 string
    Steve Ebels just suggested loctite 55. It is a string product. I tried it on one stubborn joint, Loctite 545 and 565 just didn't seem to do the trick. So far, two days later, no leak.
    BTW Andrew, it was on the Laing Heaters.
    Rob Blair
  • Tim Doran_4
    Tim Doran_4 Member Posts: 138
    Same problem
    We had the same problem a while back. Wicking and blue block did the trick.
    Tim D.
  • ALH_4
    55
    I'm surprised. I never had a problem with the 545. Glad to hear you got it sealed!
