120 V freeze protection?
Timco
Member Posts: 3,040
Should be simple, but nothing comes to mind. I have a chicken coup with a small electric heater in it. My power bill was $75 more than usual because of it. I just need it to run and keep the coup at 40*, but even on low since I sealed all thge gaps, it gets to 65-74* in there. Any ideas to keep it at 40*? Their water is in there and I like to keep them above freezing at night even though they do not need it. Maybe an AC swamp cooler t-stat? (they do not go down to 40* though)
Tim
Tim
Just a guy running some pipes.
maybe this would work
http://www.airwater.biz/white-rodgers_thermostats_1a65-641_2561_prd1.htm
if you can keep them from turning it up!
Larry0 -
Since they never do what I say, I would need to buy a guard for it. Also, it only comes in white, and I am sure they would rather have almond to match the 'natural wood grain interior'. (plywood)
If no other quick ideas (something I can find on the shelf today) comes up, this is perfect. Thanks! It was warmer in the coup than in my own house this morning since I sealed up the gaps!
TimJust a guy running some pipes.0 -
Kerosene heater thermostat
Would a thermostat used for kerosene heaters ie (the old knipco's) work? Should be able to pick one up at hd or farm type store.
Thanks, Wayne0 -
$75.00 per month for eggs
sounds a bit high.0 -
First the wife, now you?
That is exactly why I am here...
radiant chicken coop
with a domestic tank.
LOL
fuel is fuel.
eggs are fuel too.0 -
Maybe a wood burner converted to a poo burner? Plenty of that! The neighbors could just dump their dog poo in a hopper or something...Just imagine the aroma...
poo burner
Mother Earth News has some stuff on free ranging chickens this month0 -
most all line voltage t-stats
run down to 40F. I have a Honeywell T498, or the less expensive 410A.
White rogers 1A10 runs down to 36F, a few other choices in the Johnstone Supply catalog. Or a farm supply water dish warmer.
Go to DI and get a small electric single burner and set the water dish on it.
hrBob "hot rod" Rohr
Son, you need more chickens!! Chickens give off BTUs, and they will heat the henhouse for free!!0 -
chickens
As long as it's not too cold,just use a heater to keep the water from freezing.Also if you insulate with foam,you may have to cover to keep them from eating it.0 -
I know they do not need the heat, but I think they lay better with heat in the coup. Besides the water, I don't want the eggs to freeze...I will visit Johnstone tomorrow. Thanks for the advise!
- 87.2K THE MAIN WALL
- 118 Chimneys & Flues
- 113 Geothermal
- 164 Indoor-Air Quality
- 73 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
