120 V freeze protection?
Timco
Timco Member Posts: 3,040
Should be simple, but nothing comes to mind. I have a chicken coup with a small electric heater in it. My power bill was $75 more than usual because of it. I just need it to run and keep the coup at 40*, but even on low since I sealed all thge gaps, it gets to 65-74* in there. Any ideas to keep it at 40*? Their water is in there and I like to keep them above freezing at night even though they do not need it. Maybe an AC swamp cooler t-stat? (they do not go down to 40* though)
Tim
  • Larry (from OSHA)
    Larry (from OSHA) Member Posts: 742
    maybe this would work
    http://www.airwater.biz/white-rodgers_thermostats_1a65-641_2561_prd1.htm
    if you can keep them from turning it up!
    Larry
  • Timco
    Since they never do what I say, I would need to buy a guard for it. Also, it only comes in white, and I am sure they would rather have almond to match the 'natural wood grain interior'. (plywood)
    If no other quick ideas (something I can find on the shelf today) comes up, this is perfect. Thanks! It was warmer in the coup than in my own house this morning since I sealed up the gaps!
    Tim
  • Wayne_16
    Wayne_16 Member Posts: 130
    Kerosene heater thermostat
    Would a thermostat used for kerosene heaters ie (the old knipco's) work? Should be able to pick one up at hd or farm type store.
    Thanks, Wayne
  • Mark Custis
    Mark Custis Member Posts: 537
    $75.00 per month for eggs
    sounds a bit high.
  • Timco
    First the wife, now you? ;)
    That is exactly why I am here...
    Tim
  • Mark Custis
    radiant chicken coop
    with a domestic tank.
    LOL
    fuel is fuel.
    eggs are fuel too.
  • Timco
    Maybe a wood burner converted to a poo burner? Plenty of that! The neighbors could just dump their dog poo in a hopper or something...Just imagine the aroma...
    Tim
  • Mark Custis
    poo burner
    Mother Earth News has some stuff on free ranging chickens this month
    hot_rod Member Posts: 26,599
    most all line voltage t-stats
    run down to 40F. I have a Honeywell T498, or the less expensive 410A.
    White rogers 1A10 runs down to 36F, a few other choices in the Johnstone Supply catalog. Or a farm supply water dish warmer.
    Go to DI and get a small electric single burner and set the water dish on it.
    hr
  • radiconnection
    radiconnection Member Posts: 29
    Son, you need more chickens!! Chickens give off BTUs, and they will heat the henhouse for free!!
  • james k
    james k Member Posts: 12
    chickens
    As long as it's not too cold,just use a heater to keep the water from freezing.Also if you insulate with foam,you may have to cover to keep them from eating it.
  • Timco
    I know they do not need the heat, but I think they lay better with heat in the coup. Besides the water, I don't want the eggs to freeze...I will visit Johnstone tomorrow. Thanks for the advise!
    Tim
