panting vents
ChasMan
Member Posts: 472
Panting on low-pressure steam occurs as the steam moves through the piping and radiators. After the metal warms, the panting stops. As long as your system works well, quietly, and efficiently, no problem.
Panting vents
My waterline on my steam boiler moves up and down in the sight glass about a half an inch or less (which I think I'm happy with) but, the vents on the radiator pant to the movement of the water. Any thought?0 -
Stewy, I'm scratching my noggin over your question...
How do you know the vents on your radiators are panting if your watching the sight glass bounce?
I am assuming your boiler is in the basement and the radiators are in the living space.0 -
Similar thought
Stewy has big ears?0 -
One word...
Boilercam.
(yeah, I've done it)0 -
I can see how this question is strange
The main vents do it too and the radiators sound the same way. The system does whistle slightly.0 -
panting vents
i am sure the panting you hear is not from the boiler waterline movement, but more likely from some trapped, or pooled condensate in the lines. also incomplete insulation can cause this.
it's important to distinguish between the firing/pressure stage, and the vacuum/relief stage of vent operation. thats why i have a low-pressure gauge on one of my rads' vent holes.
usually adding more main venting quiets these rad vents down.--nbc0
- 86.8K THE MAIN WALL
- 56 Biomass
- 106 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 104 Geothermal
- 69 Pipe Deterioration
- 952 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
