Hoffman Valve
Reid
Reid Member Posts: 1
I have a 1925 2 pipe steam system in a 5000 sg ft house, that originally had a huge coal fired boiler which was replaced by a more efficient natural gas fired Bryant boiler. At the end of the system there is a Hoffman Differential Loop with a Hoffman No 11 Vacuum/Vapor valve on top of it. due to uneven heat, I think it is time to replace the valve, however, they have not made that vale for 35 years, and it appears it was never designed for gas/oil applications. the best I have learned is that the only valve that will work at this time on this system is a Hoffman #75 valve. Anybody have any info on this matter ?
