Anyone drill and tap 2\" on a Radiator?
that`s a <i>big hole!</i> I`ve done a few 1", but 2" <i>whew</i>, make sure you have some Rapid Tap on hand for that one.<BR>Good luck! <BR><BR>Dave
  • Daniel_3
    Daniel_3 Member Posts: 543
    I'm looking into prices of tungsten carbide grit hole saws (I looked at MK Morse) and I figure if they are not too expensive it would be great to drill out an already 1" tap from a hot water beauty slowly and then tap it for 2" so steam can be happily supplied and condensate can be happily returned. What are your experiences?
  • bob young
    bob young Member Posts: 2,177
    rad
    Maybe the one inch connection could work. how big is the radiator
  • Daniel_3
    It really wouldn't be practical since this rad is about 40 plus sqft edr and 9 sections at 38". A 1" supply for steam is just not proper sizing considering this rad. It should be at least 1 1/4 " because of the reduction at the angle valve. I don't think I'll be using it anyways so my idea is kaput =) Thanks though Bob
