PEX Question
Multicor specifies 0.156 inches per ten degrees per hundred feet.
PEX Question
Hi All, Is there a linear expansion specification for 1/2" PEX-AL-PEX tubing? Thanks, Roland0 -
Kitec shows exact same expansion rate. 0.156" per 10F-delta-t on 100ft run.
- 120 Geothermal
- 169 Indoor-Air Quality
- 396 Solar
