temp settings for pex etc
Brad White
Member Posts: 2,398
Typically, the actual standards and limitations should be printed right on the tube according to DIN and ASTM standards.
"It is rated at 73.4° F at 160 psi, 180° F at 100 psi and 200 °F at 80 psi" is from the Wirsbo Web Site.
You can see how the lower the temperature the greater the pressure it can withstand. My only concern would be expansion. Personally, PEX-AL-PEX would be my choice for high temperature systems like that, although I think the actual operating range differences are marginal at the actual service conditions.
If your tubing does not state the limitations and certification agencies, I would use something else :)
"If you do not know the answer, say, "I do not know the answer", and you will be correct!"
-Ernie White, my Dad
if i set my boiler at 180, is that too high for pex to handle?
my system pressure wanders between 12 to 20 psi depending on heat and pump operation.
so i guess im good to 180?
What if ??
What if your aquastat wonders off along with your system pressure? I agree with Brad, use an aluminum based pex at the boiler room. Here's a pic of a job one of my customers did with fostapex - very tight boiler room. Notice no burn marks.0 -
wow
It's done in layers like a lasagne! I wish I coulda thought of that. Must be 10-12 grand worth of parts on that little wall. Nice work!0 -
there seems to be a group of F-10's or F-12's
what is the sq ft of the place? for some reason the circs look large to me.. maybe only one is an F-12 the bronze body circ seems huge too... whatever.:) Tacos probably real habby
sometimes i think of something like what if...secondary high limits maybe should be required on all boilers not just commercial. Low water cut offs ,i think, have for years ...which is a good thing. ...0 -
them would be fabulous answers had my question been more along the lines of "what should i install?"
i dont intend ripping out all my pex as soon as they come out with something new. my stuff has been installed 8 yrs.0
- 85.7K THE MAIN WALL
- 50 Biomass
- 74 Chimneys & Flues
- 93 Geothermal
- 150 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 854 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.6K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
