Hot Water Heater flame problem
Jim Davis_3
Member Posts: 578
Burner is dirty or misaligned. Would take a properly trained plumber or HVAC tech.
Hot water heater flame problem
I have a 2 yr old gas fired hot water heater. When the flame fires up to heat the water, part of the flame intermittenly cuts out, giving a whooshing sound as the flame goes from full flame to partial flame back to full flame. What could be causing this, and would I need a HVAC tech or a plumber to correct this?
Thanks.
Art0 -
Need a Pro
Could be a number of things, you need a professional to check pressure,exhaust, burner alignment, cleanliness of burner, draft etc.
Make Peace you Passion!0
- 50 Industry Classes
