heating finished basement
Perry_3
Member Posts: 498
Please describe how the rest of the house is heated so that people here can provide some meaningful suggestions.
Forced air, hot water, steam, and what kind of fuel / heat source you are using (Solar, wood, coal, oil, gas).
buying a simple dehumidifier (like you can buy for several hundred dollars) in the basement should stop any mold activity. I run one in my basement all summer long. Winter it runs intermittently (normally when I am doing laundry)
Perry
Perry
heat in finished basement
we live on long island we have a finished basement with no heat. there are no vents, or anything down there ( i think that's why we are starting to see mold). we currently heat our home with oil. what are our options for heating. we will be using the area frequently.0 -
It depends
Depending on the size, exposure and amount of space required to heat varies the answers.
Perhaps 1-2 dehumidifiers with the heat they generate along with a small electric heater is enough?0
- 167 Indoor-Air Quality
