Contender MC-80 - \"FLU\" Issues
PJO_5
Member Posts: 199
Thanks Ted...both you and the tech support said the same thing - but you were first ;-)
Why don't they put that information in the manual?
Take Care, PJO
Take Care, PJO
Jumpered the switch...
and the new units - both of them - still have the same fault. They think the flue is blocked, but it's fine. There's about 65' equivalent piping length, so that's okay (less than 85" total).
The motor and fan hesitate for a few seconds on start-up...what the heck is wrong? HTP is closed for the evening, and the tech is a little miffed ;-)
Please help. Thanks, PJO0 -
condensate cup
It's the condensate cup. There is a small micro switch on the white cup. Turn the cup clock wise or tighten it to make a better contact. Most likely the drain piping used is twisting the cup counter clock wise just enough to open the switch.
This condensate cup switch is in series with the flue switch.0
- 111 Chimneys & Flues
- 106 Geothermal
- 979 Plumbing
- 387 Solar
