Refrigerant leaks
Hvacman
Member Posts: 159
Most leaks are at joints due to cracking and coils due to the thinner tubing used. Many coils have "rifled" tubing which is weaker still, all in the quest for higher efficiency... Add so-so workmanship on the part of some techs and there you have it. Most techs use a couple methods to find leaks, bubbles and detectors mainly... some like UV dyes but I'm not a fan of them... Experience is the best tool if you expect success in finding leaks.
What's
the best method of locating these? I can easily understand leaks on a hydronic system from gaskets,packing nuts,air vents etc. But how in the $%& do systems with no threaded connections and only a few brazed joints seem to leak constantly?
pressure controls
One of the biggest sources of leaks is the service valves you might have just taken your gages off of. Make sure all caps are tightly sealed. I just finished a job on 2 large Kramer ]freezers where both Cond. units had leaks in the bellows of the defrost pressure controls. A good leak detector will run about $500.00. Dont like the dyes, gets all over your guages and smells horrible. Pressure test with 150-200psig of nitrogen or use leak detector.There was an error rendering this rich post.
Leaks
ATP-Amprobe and others make an ultrasonic leak detector that the HVACR guys use. It operates by detecting the ultrasonic sounds from the leaking water or refrigerant. It works very well. It is a little pricey,but if you would use it enough, it is cost effective.0
- 109 Chimneys & Flues
- 5.6K Gas Heating
- 971 Plumbing
- 386 Solar
- 17 Recall Announcements
