amtrol flush
J.C.A._3
Member Posts: 2,980
Nickle safe Ice Machine Cleaner is the way I do it...along with the magic wand.
I don't have the name brand, but I can get it to you in the morning....I keep a 1 gallon bottle in the shop now, and replace it as used. The directions are on the jug, but I find that a couple of blasts with the wand after a good coil heating...tank empty... get things moving alot better than just throwing the cleaner in there. Chris
what is the proper...
way to flush out a Boilermate coil? Is Sizzle or acid an acceptable cleaner? I will use one of the "magic wands" to get inside but...I need to clean off the coil of a 2 yr. old 41 gal indirect that is fouled w/ iron and calcium....kpc
The owner's manual details the procedure which uses phosphoric acid (ice machine cleaner.)
Is the boiler mate manual on the amtrol website?
I looked and...
there were no instructions... Thanks JCA...kpc
Boilermate cleaning
I cleaned my boilermate when it started to produce less hot water. I followed Amtrols directions and used Phosphoric (ice machine cleaning solution) acid exactly as instructed. When i was finished the hot water oputput was like it was the day it was first installed. Do yourself a favor, don't get creative, the manufacturers instructions are the best route to follow.0 -
That is why...
That is one of the reasons why I stopped using the Boiler Mate. Along with lousy support in my area. Warranty issues and a bunch of leakers.
Tank in tank will be less likely to have that problem. Smooth coils like the Super-Stor also are good.
Kevin.....
....what is a "magic wand?"
Starch0 -
That is a
Piece of copper tubing with a ball valv attached with a garden hose adpt. This allows us to "wash off" the coil from the hot water tapping located at the top of the tank. After a bath of ice maker cleaner, the coil is then "preasure" washed with the magic wand to further clean it.
Scott
That is a
double post0 -
Thanks, Scott!
- 109 Chimneys & Flues
- 977 Plumbing
- 387 Solar
- 17 Recall Announcements
