Dielectric union
but the Super, GC, and prints call for dielectric unions. And I do not believe they will withstand the constant steam pressure required for the heating elements. I don't know, steam through rubber gaskets/washers?
  • Eileen Olive
    Eileen Olive Member Posts: 99
    Dielectric Union
    Has any one used dielectric unions on steam lines? Our super has directed us to use 1-1/4" dielectric unions on the steam supply and return. Can't help but wonder how the rubber washer/gasket will fare?
  • scrook_2
    scrook_2 Member Posts: 610
    if EPDM...
    If it's EPDM it should be fine w/ either hot water or low pressure steam.
  • why?
    Why use them in first place?
  • Eileen Olive
    Not My Idea
    Because the Print & the GC say that's what goes there. It is a 3" riser feeding 1" heating elements. I would use a dielectric nipple, if anythying. But it is there show.
  • Jim Walls_4
    Jim Walls_4 Member Posts: 3
    dielectric
    JimO
    Would a dielectric flange set up work for you? This would also give you flexibility with picking a gasket having the proper rating
    Jim
