scale in tankless heating coil
Mike.C
Member Posts: 43
Flush it out with vinegar. backflush also to loosen scales that form in one direction.
Mike.C
Mike.C
scale buildup in tankless coil
Hi all,
I have a tankless coil for domestic hot water as part of Burnham oil boiler that is clogged from hard water scale. I realize that the long term solution to this problem is a water softenning system. My question is what can I do to remove the scale buildup that is already present. Would an acid wash through the coil do the trick. If so what kind of acid and what strength. Or should I just look into replacing the coil with a new coil or maybe an indirect system.
Thanks for any help.
Dan0 -
try this
www.rydlyme.com
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"gwgillplumbingandheating.com
After cleaning out the coil install a Cuno Scale Stopper in the cold water make up line. Replace the cartridge once a year. You'll never have the problem again.0
- 87K THE MAIN WALL
- 115 Chimneys & Flues
- 107 Geothermal
- 983 Plumbing
- 389 Solar
