New steam Ng savings
mark ransley
Member Posts: 155
We have a big old Kiwanee steam heating 14 units. What do people actualy see in energy savings with new boilers. I have been told 30% is common.
Mis-applied statistics
Savings of 30% are not uncommon when switching from an older steam system or hot water system to a new modulating condensing boiler using outdoor reset. If applied to a building with new insulation and air sealing, this savings can double... not absolute but order of magnitude.
When replacing an older steam boiler with a new steam boiler, the efficiency may well be a few points, especially if you are replacing a 78% system with one that has an AFUE of 85%...
But the larger question is, what about piping, both near the boiler and away? Operating pressure? Pipe insulation?
We are talking systems here, not just boilers, in any case imaginable.0 -
The Only Reply
is "It Depends".
What type of steam system do you have-one or two pipe?
Has the system been properly upgraded and maintained?
As everyone else says it depends. Often times the savings are from having a more accurate size of boiler, better near boiler piping and servicing the distribution system so steam can go where it is needed but also not go where it is not needed as in using TRVs instead of open windows to reduce the heat in units. The additon of staged firing or staged boilers and outdoor resets can also add savings.Cost is what you spend , value is what you get.
cell # 413-841-6726
Steam Pipes are insulated, windows are new, but bills and pressure is high, pressure is 3 lb, tomorrow I am buying a Vaporstat. Venting is uneven and many apartments are hot so i am addressing that issue. But I read the Kiwanee is 82% steady state and my savings is mainly from heating less water. I wish there was a heat recovery system for the wasted exhaust heat, I have not seen any low temp exhaust steam units of 1,100,000 btu, its still a shame to throw 17% of your money up the chimney with a new steam unit.0 -
Savings
I have been told by my customer of saving of 25% , but they go for the whole ball of wax
Savings ... depends
"Savings" is a very subjective topic of conversation! As others have stated there are many factors to consider. I recently completed a project that is accurately monitored and "saw" the true results. See post on New Boiler Savings. I am now a true believer in Steam Heating Efficiency as preached by Steamhead and Dan.0 -
Overheated Rooms
Waste steam. I'd work on them before worrying about the 17% going up the chimney.
that size boiler you should have a modulating burner on it --there is a control on the boiler to drop to low fire before shutdown and maintain steam for a certain amount of time depending on what control you have ---Heat-Timer Steam timer etc.. //////////////////////////////////////////////// you wouldn't recoup much savings by just replacing the boiler --address you balance issues,insulate, tighten up the building , first then have the controls adjusted -----if that burner has a modulating control on it --you can adjust it so it runs more efficient - they are variable rate burners --lots of adjustments can be made ---got any pictures ??0
- 167 Indoor-Air Quality
