gas vs oil
jim_160
jim_160 Member Posts: 24
ive heard a lot of negative talk on gas hwh as central heat source. does renni or any mfg build a heater that will heat both home heat and dhw?
  • Jim Franklin
    Jim Franklin Member Posts: 170
    Are you talking gas or oil?
    The options will be different.
    Floor mounted or wall hung?
    Is high efficiency what your looking for, be aware this reflects the price, but could be recovered in a few years.
    You will find your answers to your questions right here, just ask the right ones.
    Good luck.
