gas vs oil
jim_160
Member Posts: 24
ive heard a lot of negative talk on gas hwh as central heat source. does renni or any mfg build a heater that will heat both home heat and dhw?
Are you talking gas or oil?
The options will be different.
Floor mounted or wall hung?
Is high efficiency what your looking for, be aware this reflects the price, but could be recovered in a few years.
You will find your answers to your questions right here, just ask the right ones.
Good luck.0
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
