Give me a Circulator..that can... HM
Paul Pollets
Member Posts: 3,671
Great idea,
Rich. I will remind you that when I went to ISH in'93, the Grundfos folks were showing off the Alpha pump with remote control programming. The chief engineer said "America is too small a hydronics market to export this pump." 14 years later, Wilo started exporting a "smart" residential pump. Grundfos has exported the larger models, but not the residential-sized circs.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=104&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Give me a circulator that will Modulate a boiler!
( Like the Viessmann 100, or any boiler that will take a 0V-10V signal)
Base it on:
Delta T
Delta P
Maybe put an Outdoor/ Indoor feedback on it
PID
Make it easy to change/service/work on
Give the Customer/Installer a exchange Programme i.e:On a yearly annual service call the Tech exchanges the circ for a very "GREEN" factory Recycled/Rebuild/Reserviced unit Regardless if it is working or not!
Let me have a simple windows based Interface that will not only Alarm me if something goes wrong but will also let me see all the data like: Amp draws;Supply temps; Return temps Running hr;Trending/Data logging;Power consumption and with an access code gain access to different levels of control capabilities i.e. Costumer access for programming setbacks of Occupied/Unoccupied modes; E-mails on system status.Reminders for Maintainace...
Most "New" Circ's are taking a 0V - 10V signal !
How about reversing this?
Or is this not Practical? maybe some other control like "Tekmar" or "Iworx"?
But from a annual service standpoint i think a Circulating pump can open very "Green" and beneficial service industry
Along with the Biers and Brats just one more thing that i will hopefully see at the ISH! Richard.0 -
We are Ready. Unleash the Best!
Hey Paul,
Yes Wilo is petty good The Alpha is not bad but i think "They" are capable of more on the residential side or they did not Unleash the Best yet! Or was this just a Wethead Dream?0
- 167 Indoor-Air Quality
