Bought a house...needs everything
Derheatmeister
Derheatmeister Member Posts: 1,633
Check on a flooring system like Roth it is Styrofoam with Groves in it for the Tubing to be installed, you can then install a backer and tile on top of this.
Or you can install panel radiators and Heated towel racks..
  • k_2
    k_2 Member Posts: 30
    new house
    So I bought a new[to me] house. It is a 70's contemporary with lots of glass and baseboard heat, and a 1971 oil boiler.
    I have lots of things I want to do and will eventually start different threads to keep things separate.
    It is a "deck house" if any know what that is. That means it has no ceilings, just 2 1/2 inch thick tongue and groove 'decking' . It makes changes pretty difficult.
    What do you suppose the possibility of adding some radiant to a pair of tile baths upstairs? insulation under would be minimal, but above conditioned spaces, 2/12 inches of wood[r, what, less than 3] It would just be for floor warming, as I will not remove the baseboard.
    I will be replacing the boiler, leaning Buderus.
    thanks
    K
  • k_2
    re
    ahhh, see, that's why I come here. i had looked at two other products, but not that one. Thank you.
    K
  • burnerman_2
    burnerman_2 Member Posts: 297
    DO NOT!!
    do not watch the movie money pit lol
