printed circuit boards
boards alone, replace it only!!!!
  • snag2.5
    snag2.5 Member Posts: 2
    Printed Circuit Boards
    On A Lennox circuit board, that the solder has popped off the back of the fan relay, is it illegal to resolder rather than replace the board?
  • Josh_10
    Josh_10 Member Posts: 786
    Depends on who you are and where you are doing it. I personally would do it. However last I checked in my area you can't make changes to a UL listed circuit board unless it isn't required that the board be UL listed. It would most likely void the manufacturers warranty as well.
    I would check with your local rep and see if there is possibly a tech service bulletin on the component you need to change. In that case there will be a factory proceedure and the change will be completely legal UL listing or not.
  • Marty
    Marty Member Posts: 109
    nope
    nothing illegal about it if you are willing to take on all the responsibility and voiding any warranties. I would in my own house as a temp. fix but never for a customer for liability reasons.
  • Guy_6
    Guy_6 Member Posts: 450
    the world
    Unfortunately, in the world we live, anything that you do "outide the box" can land you in a world of hurt. You re-solder the relay and 6 months later the fan motor burns up (completely unrelated), the liability may come back to you. Your intentions are good, but the lawyers occasionally feed on them.
