printed circuit boards
boards alone, replace it only!!!!
Printed Circuit Boards
On A Lennox circuit board, that the solder has popped off the back of the fan relay, is it illegal to resolder rather than replace the board?0 -
Depends on who you are and where you are doing it. I personally would do it. However last I checked in my area you can't make changes to a UL listed circuit board unless it isn't required that the board be UL listed. It would most likely void the manufacturers warranty as well.
I would check with your local rep and see if there is possibly a tech service bulletin on the component you need to change. In that case there will be a factory proceedure and the change will be completely legal UL listing or not.0 -
nope
nothing illegal about it if you are willing to take on all the responsibility and voiding any warranties. I would in my own house as a temp. fix but never for a customer for liability reasons.0 -
the world
Unfortunately, in the world we live, anything that you do "outide the box" can land you in a world of hurt. You re-solder the relay and 6 months later the fan motor burns up (completely unrelated), the liability may come back to you. Your intentions are good, but the lawyers occasionally feed on them.0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 64 Pipe Deterioration
- 917 Plumbing
- 6.1K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
