It gets serviced every year
I went with a becket as the service companys are well versed in them in my area. The AFG model. It was not the nicest install I have done as it was a rush but I have a pic of it. They never look as good as if you can clean out the foot print of the old boiler first. I had to pipe tjis one and slide it in after I cut loose the old one. Da does not like the expansion take on the return but I figured I would try it on this one. The indirect was installed last summer as well problem clogged the old amtrol unit they had.
cell # 413-841-6726
