Burnham Alpine
Jim Wy.
Member Posts: 43
I've got that 2500 sq. ft. slab radiant job I used two Rinnais on in 04 that we'de like to replace w/ a real boiler. The Burnham Alpine seems to be the best deal in my area but it is really important to me that my costomer have as few problems as possable even if we do have to either give up some eff. or pay more. I've always installed Allied M.G. @ 84% or Rinnai. The allied boilers have given very little problems but mod con seems like the way to go for radiant slab.
Been using the Alpine for almost a year
We have 9 installs so far and not ONE Problem. With the low water application you should 90%+ way better than a Rinnai. Your customers will love you for it!!!0 -
Indirect or tankless for domestic ?0 -
Indirect
Coil is not an option on the wall hung modulating gas boiler0
- 86.8K THE MAIN WALL
- 56 Biomass
- 107 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 104 Geothermal
- 69 Pipe Deterioration
- 954 Plumbing
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
